P0420
Jan 29, 2025
Hi all its my first post so please be gentle.
I've got a 2016 Leon 1.8 petrol and i am getting a intromittent P0420, the idle feels rough and there is some fluctuation in the RPM needle around 1mm fluctuation it feels like a misfire without there being a code or any indication of a misfire on the OBD misfire counter. It drives fine no hesitation and plenty of power when accelerating. No visible smoke from the exhaust. Seams to be using a bit more fuel than normal.
Mileage is 55,861
Serviced 2 months ago.
Also could anyone tell me if the Pre cat 02 / Lambda is a wide band sensor as it has the 4 wire connector and not the 6 wire that would normally indicate a wideband sensor. The reason for asking is the 02 sensor V reading is not in the V range i would normally expect.
Any advice would be appreciated.
Jan 29, 2025
Ive put this in the wrong section it was ment to go in the Leon section so apologies, its my first time posting on a forum. I cant find how to move or delete it.
Jan 29, 2025
Quick correction of myself its the 5 wire connector not the 4 wire. I have uploaded a minute video of the live data of the 02 sensors.
