Hello. I use to use forums a number of years ago. I have signed up in the hope someone may be able to give advice.
I have a 2018 seat leon 1.5tsi. The gearbox bolt dropped out the other week when the family was on holiday. The subsequent engine rock damaged the bottom radiator hose, and it dropped all coolant. The aa arrived patched the hose but missed the engine rocking. So it damaged the hose again and dropped its coolant. Once home I found the reason fir the engine rocking. Since then, I have replaced the bolt and lower coolant pipe, but within 30 of start up, the fan kicks in, and it states it's overhearing.
I scanned it and a code P2B61 same up. Searching for it, the code is for an Engine Coolant Flow Control Valve Stuck Closed. I called seat to get the part but they had no note of such a part.
I had considered it was the auxiliary water pump.
Does anyone have a rough idea of a possible part fault?
Thanks in advance from a old school car enthusiast.
