Right might take a while to explain so sorry before i begin. I was driving home on saturday (very hot day) about midday (first time id driven the car that day). id been about a mile and decided to turn on the air con (first time ever, other than a few seconds to see if it worked) as i came onto the motorway. Must have driven about 7 miles and the temp gauge started to go up and got to 3/4s so i quickly pulled onto the hard shoulder and knocked the engine off. opened the bonnet so it could cool a bit. left it for 5 and then drove off with the aircon off and the heaters on full heat. temp was fine until the missus comlained that she was boiling and so i knocked the temp down to 23 (no aircon still) and after about another 2 miles, temp gauge went up again, so pulled over again. left it again and then was able to drive to my house (3 miles or so) with the heaters on full heat again. i looked on here and found a link about the fans failing so thought that it was the issue, but i checked the fans last night (p.s. i havent driven it since) and both seemed to run fine, and i ran the engine for approx 20 mins with the air con on hot, cold, on/off and the temp needle didnt move from 90. The fans kept going the whole time. So now im really puzzled as to what caused this. I have ordered the resistors to bypass the internal ones in the fan that burn out all the time (rapid electronics are the cheapest for them, (£3.45 each, order code 62-8176)) and im getting vagcom tomorrow to check if there are any sensors gone, but wondering if anyone had possible causes of this or a known fix. Cheers all
