Opinions wanted!
james walker
cooling is the key people
May 24, 2007
5,121
retford notts
i have it, awesome piece of kit, worth every penny... save me loads in fault code readings alone.
accurate bhp and torque/boost measurements. lambda settings also accurate. easily viusible screen. had it 8 months with no problems.
jwfcms
384
UK Yorkshire
got one myself, payed £ 170 with the air vent pod aswell easy to fit just plugs in and pushes in the the vent hole, great bit of kit for fault code reading aswell and obviously all the info it gives you, get the air vent pod have a look on racediagnostics.com they supply the vent pods and fits straight in there with no problems or messing about.
Baldwin
55
Sweet where did you locate it? to the left or right of the wheel? whats it like to run the cables for it?
theres one on race diagnositics for £210 with the mount.
Defo goin on the to do list.
Does anyone have any pictures?
cheers
jwfcms
384
UK Yorkshire
it goes into the air vent to the right side of the steering wheel, near the window, the vent on your dash will just "pull" out then you remove the slats by pulling them out and the vent pod and computer thing just slides in and holds in place like... just replaces the vent, keep the vent closed when the heaters are on hot.. to run the wire i got a stanley blade/knife and cut a slat into the bottom of the vent ducting, pushed the wire through and connected it up to the vent pod computer, pushed the vent into place then remove the lower part of the dash where the light swicth is, easy to remove a few torx headed screws underneath and in the fuse box area. 5 minute job. even tho saying you need to remove that part of the dash sounds like a big job it isnt. run the run under there to the diagnostic port and plug it in :D
ill post up a picture
james walker
May 24, 2007
5,121
retford notts
i ran mine through the vent, into the fuse box, under the das near the steering wheel, then behind the pod where the ecu port is.... no undoing anything, totally hidden wires, took around half hour to fit.
payed 130 all in for mine, got it whilst they were testing for the leon fitment:happy:
Baldwin
55
Cool mate, i know what you mean about removing the dash, i think you just need to do it and get over the fear!
Look forward to seeing a pic of it all!
Cheers!
CupraMVR
Awesome GTi Technician
Oct 19, 2006
1,371
Crewe Cheshire
They are really good piece of kit. i had 1 in my car for a while on a demo;
my favorite was the exhaust temp, got mine up to 950 C :D
on the never ending list of stuff to get aswell
