Open cone filter help (now fitted)
Jun 21, 2008
673
Wolverhampton
Evening people, i want to fit an open cone filter to my 20vt FR. i had a look on saturday brieftly but didnt want to make a mess of things!
Basicaly, do i remove the airbox, filter and breather pipe?
I can see a screw from the airbox to the MAF, do i unscrew this and the airbox pulls free of the MAF?
I hope this isnt a repost, ive searched but i cant see anything that helps me directly!
tom167
bucksvag.net
Mar 27, 2006
201
Milton Keynes
the mafs held to the airbox with two philips screws, remove these then pull the maf housing free of the airbox.
then the airbox is held in with a 10mm bolt next to the washer bottle, and possibly another behind the battery. Then just pull it free :)
If its the same as tdi lol
Jan 14, 2005
1,308
Cannock/Wolvo
yeah 70mm maf on the fr. I tried the dynatwist inducton kit on mine some time ago but opted for a green panel filter and smoothed airbox in the end. Heatsoaks a big problem with the mk4
Jun 21, 2008
673
Wolverhampton
well, its now fitted and makes some wierd and wonderful noises, it seems to suck like a hooker lol and the standard DV is quite loud too. stil gonna get the panel filter, just that i an open cone one knocking round in the garage
Damoegan
Sir Bob,a geordy legend..
Oct 15, 2007
8,993
Newcastle
You need a Forge TIP and a Forge DV now and the sound will be so much better.
I went from a Green panel filter to a open cone filter and prefer the open cone.
Jun 21, 2008
673
Wolverhampton
im on the case for a 007p lol, this was just a quick free mod for me.
Is the TIP easy to do? im not that experienced with cars but willing to try!
whatis that a blue bit a reducer for your filter? if so what size is it?
Damoegan
Oct 15, 2007
8,993
Newcastle
Forge TIP is quite easy to fit, very straight forward once you get into it.
No reducer from MAF to filter. The blue thing you can see is just a cable tie attaching the filter the support bracket I made. lol
Jun 21, 2008
673
Wolverhampton
ah ok. i couldnt tell whether it was silicone or not lol.
cheers for the advice, i may give the TIP a go when the weather gets better!
May 29, 2008
675
Aberdeenshire
this is my job for weekend, got a cone filter from a member on here! running a green cotton panel filter.....so if im impressed with the cone filter that will be up for sale!
quick question, i know the heatsoak in the mk4 is a problem...what have you used to duct cold air to the cone?
Damoegan
Oct 15, 2007
8,993
Newcastle
Nothing at all mate, I have no cold air feed.
You wont have any problem with heat soak as the Seat Sport intercooler is so good.
After a 4 hour drive coming back from P-Torque the fitler was ice cold to touch. Same thing after a good logging session too :D
May 29, 2008
675
Aberdeenshire
thats what i like to hear!! save me running a cold air feed :) can focus my time on re-fitting my splitter!! bloody snow!!! lol
diss_50
MK4 IBIZA CUPRA
Aug 21, 2007
1,055
Damoegan, what did do with the standard cold air feed? Why not run it into the side of the cone?
Damoegan
Oct 15, 2007
8,993
Newcastle
Its sitting in the loft.
I didnt use it coz it would a) look crap as I have removed all the SAI and EGR/Combi valve to clean the look of the engine bay. b) I dont think it realy needs a cold air feed.
But I might try and squeez some ducting down the side of the battery and down to the front bumper when I can be bothered.
