Only one wiper working
Jul 25, 2023
Front drivers wiper is not working other side working perfectly all speeds,linkage is free moving and no damage to spline and free movement the 30A fuse is intact the plug is 3 wire and has a good earth (brown) permanent feed (red / white )has12v the other (green/white) l believe is the command wire,is there a relay or does each motor have its own relay if so the location,it’s probably easier to replace the motor but I want to know the actual fault tia,regards
rdraheim
84
16
I was responding to someone else on this forum and I know nothing about the year of your car or the Altea in general.
However, I would check this video out and use the info within for wiring diagrams and the like:
Relay assignment [ panel in video at (0:43) ], maybe it will help someone. 1 - Terminal 15 voltage supply relay 2, -J681-, (460) Slot B1 [KL15] 2 - Heated exterior mirror relay J99 (449) Slot B2 [SHZG] 3 - Heated rear window relay J9 (53) Slot B5 [HHZG] 4 - Dual tone horn relay J4 (449) Slot B6 [HORN] 5 - X-contact relief relay J59 (460) Slot B9 [KL75] 6 - Double washer pump relay 2 J730 (404) Slot B8 [DWP-V] 7 - Double washer pump relay 1 J729 (404) Slot B7 [DWP-H] 8 - not assigned, Slot B3 [HDF] 9 - Terminal 30 voltage supply relay 2 J689 (449) Slot B4 [KL30]
