Had some running issues on my LC when i bought it. Had the usual fault codes for pressure drop around turbo area, running too rich etc. Have changed various things including:
4 Coilpacks
MAF
Dump valve
Jetex filter
Recently bought a turbo hose kit, only had the chance to fit 3 of the 5 (tb to ic, dv to charge pipe, n75 to charge pipe) . Now the pressure drop code which i've had for months has disappeared but now have a new code:
17956/P1548/005448 - Boost Pressure Control Valve (N75): Open Circuit
Possible Symptoms
Irregular behaviour
Loss of power
Limp mode
Possible Causes
Wiring and/or connections faulty (short circuit)
N75 faulty
Possible Solutions
Check wiring and connections
Check / Replace N75
I can remember that getting the small hose from the n75 was a right pita, is it possible i could have damaged the n75? Are they quite fragile, like mafs?
4 Coilpacks
MAF
Dump valve
Jetex filter
Possible Symptoms
Irregular behaviour
Loss of power
Limp mode
Possible Causes
N75 faulty
Possible Solutions
Check / Replace N75
