Eh up
Thought id start a fresh thread as im a little bit miffed with cabin heat problems.
A couple of weeks back i switched out my heater matrix as i had no hot air, matrix was blocked when i tested after removal.
Flushed the system with DI water till it ran clear fitted a new Nissense matrix and replaced di water with g12 evo bleeding the system with VCDS.
Great heat until Thursday last week when vents got cold when blower was on full and heat set to HI.
Re bleed system with VCDS and there was no improvement, so yesterday i removed the new matrix and water flows freely through it, not blocked. Calibrated air direction flaps. I get hot air on a low blower settings, so for me the matrix just is not getting enough flow to keep the air moved on the max blower setting hot. Its not blowing water out of the header tank when it regens at this point.
So anyone know what the problem may be ?
I know there is an electric pump on the circuit, i thinks its the one near the oil filter TDI184. Is that right ? How to test this anyone know ? And there appears to be a heater control valve N82 in the circuit somewhere. Anyone know where that is located ?
