On Screen Display - " no entries available"
Willie1892
12
2013 Seat Leon 1.2 S Model - Just driving my car today and noticed that the speed is not showing up on the Car Instrument Panel - its states "No entries available". All other small items on this screen seen to work ie time, gear, total mileage, ambient tems, mileage since last fill. its just the BIG screen seems to have an issue. Can any one point me in a direction, remove battery and replace - could this reset the system. Any advise please.
chrisRibiza
1,194
51
The only screen I get the "no entries available" is on the faults screen.
Do you have a photo showing the problem? Are you sure you are on the correct screen?
Willie1892
12
doh ......Yes it was on the fault screen.
Thought by removing the key it would have defaulted to normal screen ie MPH.
Just changed this and everything now ok
Thanks -
niallain
273
54
Cardiff
There's two screens on the gauge cluster, one is Driving Data which shows speed/range/mpg etc, the other is the same function as the "Car" button on the headunit. Quite often you will see "No entries available" as nothing is wrong with the car.
Select the different view for the gauge cluster using the steering wheel controls on the right hand side.
