Oil Pressures
Dave_R
Save a Sheep...Buy Brembo
Sep 20, 2004
3,666
South Wales
Right been watching my oil pressure gauge lately and want to compare to other owners (if they have a oil pressure gauge that is). What pressures are you getting?
All these are when the car is warmed up, oil temp at 80-90 degress.
On idle around 30 psi
At 2000rpm around 60 psi
At 3000rpm 75 psi
When I'm flat out just above 75-80 odd psi
I have a t-piece off the low oil pressure warning light sender and I'm thinking if the oil pressure gauge sender is reading the pressure inside the t-piece more than the oil pressure.
Anyone know a bit more up oil pressures? I always thought rule of thrumb was 10psi per 1000rpm? Gonna start looking into it more but F1 is on soon :)
crezz
pedro motorsports
Jun 30, 2007
4,397
Woolacombe
im when mine is cold its pressure is at 5 bar (72psi) on tick over, warm around 2 bar (29psi) tick over...reving right up to 5 bar (72psi) again really but havent really looked too much whilst in gears either trundling along or giving it some
toonfiend
Hail to the Plug!!!!
Jun 27, 2008
159
Start from cold about 60 - 70 psi, then drops to 40 psi once choke off.
Once warmed up at idle 10 - 20 psi
`Conservative` driving ie: under 3K gear changing about 50 psi
`Ragging the nuts off it` driving ie: 5K and over gear changing, anything up to 80 psi
Just come back from a long trip up and down the A1, she was sitting at 70mph, just over
3K and the pressure was showing about 55 - 60 psi (ish)
Mines an aftermarket gauge and to be honest I dont think its that accurate, looks good though! :lol:
