Unscrew cap (was VERY tight the first time I removed mine, it is normally threaded) and remove, slide filter off cap mounted shaft, use oil sucky sucky thing to get oil out of base of housing, change seals on cap/shaft, put new filter on shaft (made sure its the right way up), refit cap.
I use one of these, I was a bit worried it would make a mess of the plastic cup but it has hardly marked it. Comes with an adaptor for 3/8 or 1/2 (which is useful to have anyway)
