Anyone running a Mocal oil cooler? Or any other oil cooler? Been looking into it and the only viable option seems to be running a sandwich plate, however there isn't much room around the standard filter at the moment anyway!
If you've fitted a sandwich plate what did you do with the standard oil cooler, did you bypass it or leave it in place? Ideally i'd like to leave it as all my gauges are running off it, and the sandwich plates don't seem to take this into account.
If you have fitted a sandwich plate and kept the OEM water jacket did you have to run a shorter oil filter, if so what did you use?
