Oh No, Air Con Warm - Regassed 2 weeks ago.
WHL_Spurs
In the car I got it topped up 2 weeks ago, noticed on saturday after I used the air con that it just stopped working after I switched off the car, Wondering what it could be as the re-gassin detected no leak yet now its blowin hot air.
Ive done a search couldnt find anything similar.
Some help please i have a heat condition which means i dont function well in the heat or temps over 20degrees.
daboy3000
No Longer a Seat owner
Jul 2, 2008
710
Oxted
What system do you have, climate or A/C, are you sure the A/C part is on and not just the heater set to cold?
dkw
51
you need to go through the diagnostics and see if there is any error codes. hold the re-circ and manual flow up buttons to get to it, use temp up and down to scroll through and the recirc to select. i think the first one will give any error codes, if its hi/lo pressure then it might need regassed, but that seems odd to have happened so quickly.
dave_ph
Jul 12, 2006
411
Somerset
www.vagowners.co.uk
I had this with my lcr not long after I got it. The dealer originally just regassed it and within a couple of days it was screwed again. Turned out to be a leak in the compressor, which had to be replaced (god bless warrenty) worked fine after that
WHL_Spurs
It's the normal A/C button mode.
I took it to my friend who works at Kwik Fit.
They didnt put dye in as he was jus re-gassing.
dkw
51
next time you get it regassed as them to dye it, then get a uv light on it. any leaks will show.
