AdamCupra
Hi Everyone, Ive got some odd problems with my car "1.8 20 vt cupra ibiza"
First of all, i had just started the car up this morning, it had been on approximatly 30 seconds, i heard some beeping and the little red warning light on my water temp display was flashing, however my water temperature was still stone cold, i gave a little rev and another 60 seconds later it went off.... this also happened again today while in traffic, however the temperature never moved above 90 degrees...
Second of all, when i first got the car the waterpump used to always run on after i switched the engine off... however now its intermitant.. when it does come on, the pump itself sounds like a bag of hammers... 'Queston, is it the main water pump that runs on or it there a secondary pump???'
Thirdly, when im on a motorway or traveling at a constant easy going speed, my engine doesnt hold it temperature... the car has done this since i have gotten it...
The reason why ive put all 3 issues up is that i believe that all the issues could all be related to one parramount issue...
Personally i think the car has a broken water pump and a broken thermostat... but if anyone here could shead some light on it, that would be fantastic....
also, wheres a good place to get a waterpump if it is that, which is broken... ' apart from the stealer'
Thanks in advance
Adam
Thanks in advance
Adam
