I think you have the clock running against you for a free upgrade of the maps. You can read out the FEC navigation value following the
resource. Last two characters and see whether you can get an update in. Suspect not since March 2019 with one year added would clearly put you out side of the one year complimentary Mapcare update possibility. It is the mib2 high you have on that. You will see the Jukebox listed on the Media button. That's the spare SSD memory in the unit that you can
store music on in addition to SD card / USB - only the mib2 high has that feature, mib2 standard does not.
Then we get into torturous threads the latest is this:
I did once trawl all the pages of the SAT Nav thread and got lost. Can I just get a new SD card or something better. I was used to updating the TOM TOM Map and re newing my Online subs on the Renno Megane. So looking for an easy way that is TECH stress free as that was.
www.seatcupra.net
I'm sure Polly had asked me that many months ago
. Attention to posts 29-36. You really need to take the retrofit route if you want the ability to update your high maps. If you get a retrofitter to give you this FEC you are good to the year 2074, although I think VAG won't be supporting Mib2 map updates by then (probably got 5 to 10 years to run on them updating mib2 high maps ... Suspect upper limit).
073000EE
You keep the hardware they alter the parameter file the unit reads. You can also have the firmware updated as well which might be offered. I mention the current release in that thread, 1447. That's the program that the infotainment system runs under. Any known bugs removed or improvements in functionality get put into these firmware updates. You might be on that release, you can check.
Nb mib1 was never fitted to
Ateca Cupra's. All non face lifted
Ateca Cupra's sold in the UK have the mib2 high (Seat calls Plus). In Europe to my knowledge they were mib2 highs. Outside of Europe, on this board the standard mib2 unit. Israel, Australia / NZ. Not sure why Seat didn't offer the high units in all regions. Mib2 high was treated as the luxury unit.
