noisey climate control in freezing??
marcordoba
Hi,
have only had my 05 tdi cordy for a month now and today was the first day of winter 1 degree. When i started the heaters on the car it sounded like an outboard motor / lawnmower / kid with cardboard in his bike spokes. It stayed still noisey for the journey to work. Could it be leaves in the system or knackered fans?? :cry:
I asssume this isnt normal in cold weather, or do I need to take it back to seat with ten days of my warranty remaining? Am going to go out later today and try it when its warmer outside.
Any advice appreciated....:clap:
Muttley
Catch that diesel!
Mar 17, 2006
4,987
31
North Kent
Fan blower, I would have thought. Possibly something has come loose in the intake hose and is bouncing off the blades, or maybe the motor bearing has gone and the whole fan is loose. Definitely get it checked out under warranty - it may need a new blower, and it shouldn't have worn out yet.
Is this the first time you have had the fan on for a while?
marcordoba
yeah since they replaced my windscreen yesterday at autoglass hmmm.... Going back to them this afternoon then seat tomorrow if it isnt something they've done
andy43
46
Sounds very much like glass has dropped down the air vents to me and its rattling around down there, a friend had a similar problem in a Toyota, the windscreen went and when they replaced it they managed to drop glass chunks in the vents.
asthpsw
524
Southampton
Thing is to try the Fan with & without the Air Con engaged...................I had exactly the same "sounding" problem on my Climate Control & it was the "Clutch" that engages/disenages the Air Con Compressor.
Paul
marcordoba
cheers bizarrely stopped last night and hasnt been heard of this morning so crossing fingers it was a leaf...
daveyonthemove
Smile if you like SEAT's
May 14, 2006
1,519
Wrexham
Unlikely to be the aircon as it isn't meant to work below 5 degrees, and although it does, i've not known them to work below 2 degrees.
