Got a couple of strange noises coming from my Ibiza.
1.This has only just started happening and is gradually getting more frequent. Its a ting sound as if something is heating up and expanding against something else. Or as the chassis twists under cornering or throttle/braking.
At first I thought it was the drivers seat base. Then this evening the car was off and I was looking underneath in the fuel cooler area and the noise happened again!
Sounds like its coming from near the rear of the fuel cooler but I couldn't quite track it down. Any ideas?
2. This one has been around ever since I've had the thing. Wide open throttle in 3rd / 4th gear from around 1750rpm up to 3000rpm there is a noise that sounds similar to a heat shield rattle. I can hear it, everyone else can hear it unless they work for Seat in which case they can't hear a thing.
It's not the undertray or pipework going to the IC.
Its only present on full throttle acceleration as is gone by 3000rpm.
I've had a look at the exhaust heat shield and none of it seems loose or anything.
Any ideas on that one?
