Noise from the clutch?
Glovepup
Cupra Lova
May 27, 2006
450
Sevenoaks, Kent
The other day I was reversing and I noticed a noise when lifting the clutch. I'm not sure how to describe it, but I suppose it sounds like a dull pop.
I think it may doing when going forward but it is really noticeable when reversing, and pressing/lifting the clutch quickly a few times and it's obvious the noise is there.
My question is, is it normal??
Schiller
Have it since the first day...I have also changed (in guarantee terms) a pair a set of clutch, and after leaving the dealer the same issue at the first second...
Probably something we must learn to live with, although terribly annoying....
thestonegate
Dan & Khym
Mine does this too until the car reaches its optimum temperature!
Mine does it has I change gears and lifting off the clutch I get a little Tap/Pop, but only when the engine is cold, when its warmed up it doesn't do it.
Is this normal?
I drive 08 Diesel FR
wobblelino
59
Herts
I had a problem iwht the clutch where everytime I depressed it i got a creaking noise.
Took to the dealer and repaired it - apparently this is a common fault on Leons. Although apparently it doesn't do any damage it was annoying.
saintsfanno1
49
I had this too, sounds like the eye of a spring moving badly up and down as the clutch is pressed.
Ofloaded a can of spray lube on it, and all is well.
Put it down to "Plastic Pedals", ..............unbeleivable
20K on and all is well.
