My cousin has an 03 plate 130 tdi sport & cant get any cold air through the climate control or when the air con is on . Any ideas please
Im sure you know this.. but just in case:
what temperature is it set at when you try this?
As its climate control, if the ambient temperature is around or below the temp selected it wont be cold as the system knows it doesnt need cooling to achieve the temperature.
If you put it on 'low' then it should be cold.
Does the snow flake sign come on when selected and stay there?
Disconnected the battery for 10 mins , everything is working fine now ???????
Hi guys, I'm having a similar problem and I hope you can help.
My aircon works fine at night but doesn't cool well during the day, thought it might need gas as the car is 3 years old so I took it to the dealer to have it serviced and regassed. I had taken it 2 days earlier for a service (same dealer, problem was already there but I forgot to mention it) and they said there were no fault codes on the car. Now they're saying the signal from the climatronic to the compressor is weak and they need to change the climatronic computer which is of course quite expensive, and that there is nothing wrong with the compressor or the gas.
However, the compressor does turn on with the AC and does blow cold air (though not as cold as it should). Car is out of warranty and I'm quite sure the dealer has no idea what they're talking about but unfortunately I'm in Mexico and there is not a single shop I trust 100% so I'd like to know what needs to be done before spending large quantities of money while different shops try out different solutions.
