No brake's !!!!!! Help
meltonlad
391
huntingdon
lastnight and tonight when ive got into my car and driven off ive had no brake's.... but after pumping on the brake pedal 5 or 6 times they come back to life. has anyone else had this problem or could it just be the very cold weather ?? :confused:
Ronin225
4,652
22
Worcester
Could be air in the fluid, check the resovoir level to see if low
Sometimes the vacuum piping splits for the cylinder but forge do a strengthened replacement but i doubt it would be that
How old is the fluid too, has it started to absorb water and needs changing
meltonlad
391
huntingdon
i will check level tomoz. not sure on last fluid change so i think i will get it changed anyway. car been standing over 24 hrs when no brake but once i pump brake pedal 5/6 times all ok even after standing over 3 hrs all ok. im hoping its sumthing to do with the weather.....
sypher1987
Same Here
I have been having the same problem, twice now ive had no brakes at all and when im driving around sometimes the pedal is normal but sometimes it goes to the flor before i get anything, then when i pump it its all normal for a bit.
I checked all the pipes underneath and it looks okay, only thing i did find was when i checked the master cylinder i found oil on it and discovered a hole in the turbo pipe. I havent checked the vacume pipe though, where is it?
