New rear dampers and coil springs - but no damping!!!
Feb 17, 2008
523
huntingdon
fitted my new rear dampers and the rear coil springs (h&r -20mm) to my ibiza ('97 gti 16v). all seemed to go well untill i noticed a knocking coming from the rear right shock. had a look and to my horror..this crazy s**t was happening! :-o:wtf:the left damper is fine and behaves as it should, but to me, this would mean that the right shock is riding purely on the spring with no damping whatsoever! anybody any ideas? the dampers are KYB OEM spec dampers and both shocks were assembled in the same manner (i.e reverse of disassembly of the old ones!)
Black TDI Turbo
Shussssh Its A Diesel ...
Oct 2, 2005
1,175
North East
I did the same on my mk3 cupra, bet you havn't fitted the little metal sleeve on the strut before fitting the top metal cap. i had the same all looked fine i stripped them and refitted, tried all sorts until i looked on the internet for answers, finally found i was missing the metal sleeve off my old struts, checked them and i had indeed missed it off, stripped and refitted and all was ok.
Feb 17, 2008
523
huntingdon
i don't suppose you happen to have any pics of the offending item? Is it a metal tube around 2 ish inches long? If so did it need to go on the strut before fitting the metal top cap? Cheers for that mate
Feb 17, 2008
523
huntingdon
that's awsome fellas! cheers for a fast response! very much appreciated. it seems i put the metal sleeve on AFTER the top cap and then screwed the nut on the end to hold lot together.!
Feb 17, 2008
523
huntingdon
sorted it! the metal tube was in the right place, but there is a small sping clip that sits in a groove near the top of the strut that connects the top cap to the strut, it wasn't in its groove so that then enabled the strut to move freely without moving the top cap. i'll post a pic up for future reference. i've also got a comedy "reverse germanic" stance as it's lowered at the back but standard at the front!
Feb 17, 2008
523
huntingdon
on the upside to the weird stance, cos the front is fairly soft and the rear is firmed up a bit the turn-in is incredible! the front just grips and back end just kind of skids round in a very controllable oversteer. i think the front and rear strut braces are helping too. i just hope that replacing the front springs with stiffer ones won't ruin what is now very good handling!
