New pads with free double sided tape...
BlackFR
1,724
Not too far away
Just got the new pads to go on the rear of the ibiza from the dealer and they have double sided tape on the back of them:
Is that to stick the piston to the pad to prevent squeal? if so presumably you don't add any copaslip to the back of the pads?
kriso
_______ C U P R A _______
Jan 29, 2007
2,325
Brighton
I think they are just there to cover up the stuff already applied to the pad. I had some tape on mine and removed it before fitting.
RUM4MO
8,028
1,093
South Scotland
Yes you do need to remove the backing paper from the sticky tape, and yes its the anti-squeal "thing". That is the trouble with buying most aftermarket pads, they come without the anti-squeal pads - my Passat B5 sounds just like a taxi with its ATE aftermarket pads from ECP.
You have ended up getting the right bits by going to the right place, I am still waiting for my right pads from an aftermarket outlet - may need to wait a little longer though!!
BlackFR
1,724
Not too far away
Cheers RUM4MO
All done this morning before the rain started!
Nothing was seized so I didn't even get to play with the mallet.
Squeak free and effective braking has been resumed, now to do the front wishbone rear bushes.
RUM4MO
8,028
1,093
South Scotland
Good news, I also had some luck today, my OEM (Textar) rear pads that are exactly the same as used at factory (same as your VAG ones but with wear sensor) arrived today - I just wish the aftermarket outlets would try to buy in the correct pads for all the model variants they claim to cover - and not just buy in something that might, if you are not too choosey be okay!
