on part throttle i have hesititancy issues, as in part throttle seems to pull back and hissing sound(hard to describe)feels like air going in and swirling around somewhere then going through to give power.....
now, i have run vagcom logs, maf is fine, boost is fine so id say the problem is pre turbo... if the maf measured the metered air then it was escaping from the tip somewhere could this cause hesitancy and lean running? can definatly hear intermittant hissing from the engine bay but struggling to pinpoint it
could a problem with the tip (samco uprated silicone, approx 4 years old) cause this, i have checked all pipes under inlet manny, there is some oil under there but im knacked if i can find a split anywhere.
if boost on vagcom is good then surely the problem is pre turbo?
only other issue i see is running slightly lean on requested and actual?
help would be appreciated if anyone else has experienced this.
dv is forge 006 and has been serviced recently running yellow spring, was like this before on standard spring?/
when driving the induction kit makes a lot of whoosing noises and sounds like dart vader on speed.
hmmmh
hmmmh
