need vag com
sambryant
RoadRunner meep meep
Mar 26, 2009
4,848
Bristol
hi all. i want to get a vag com. i need sum 1 to point me in the right direction. i want a cheap 1 to start with. in the future i will get a desent 1. so any recommendations would be great.
thanks all
Theresias
When you're thinking about going cheap, you may want to take this into account...
Shareware:
- Cannot do Auto-Scan
- Won't display Text for all Fault Codes
- No Basic Settings (so no TBA, Xenon levelling, etc or checking timing on TDI's)
- No Adaptation Saving (so no changing of locking/lights/horn behavior)
- No Output Tests
- No Tech Support from Ross-Tech
Limitations of 311 and 409 even if Fully Registered:
- No Generic OBD-II
- Won't work with CAN-Bus vehicles
- Fewer fault code definitions and label files
- No built-in Activation (you'll be limited to a single PC)
- No Advanced Measuring Blocks
- No Direct Access for Adaptation and Basic Setting
- No Acceleration Measurement
- No Automated Service Reset
- No Session Log Capabilities
- No Support for Guided Readiness Scripts
- No Optical Bus Diagnosis
- No Battery/Gateway Coding/Long Coding Assistant
- No (Automatic) Updates
- No ECU Mileage Reading (EDC15/16)
- No Support for Windows Vista and Windows 7
...and some more minor things as well. ;)
If you decide to go real...
Directly on the first VAG-COM/VCDS page in our online shop system you'll find the US & Canada Application Charts for information regarding which interface will work with North American models and the typical modules supported. Additionally there is the VCDS World Spec Compatibility Charts for all non-US models.
That should give you straight answers what systems support which models and which are best for your specific vehicle. Since you didn't say which car you want to work on its hard to get into specifics...
Mr Roboto
Domo Arigato
Mar 14, 2005
470
Sussex
As above get the full version.
£250 is not alot considering a dealer will charge £40-£50 to hook up their software outside of warranty.
