Need help fitting Forge TIP lcr 225...
J0N
Defected!
Not really sure what to say Craig, take the old one off taking note of where everything goes and put the new one on. It can be a bit fiddly getting to the jubilee clips but the TIP itself goes onto the turbo easily enough. You'll be fine.
D.K
LCR 225
Oct 24, 2007
6,408
se london
I have'nt I'm afraid, if you take out the airbox and engine cover you will be able to see most of it.
Mr_Magistus
who am i???
Feb 22, 2005
148
UK
I did mine without any guides or anything. Make sure you have clips on each hose and fit the bottom one first. Work your way up.
Take you time and make sure all the connections are tight and you have no chance of an air leak.
Ronin225
4,652
22
Worcester
You can compare it to the old one for lengths incase some trimming is needed.
A very light smear of oil can be used for assisting pipes on
Only take a couple of hours for a non mechanically minded person to do anyway
