Need any help or advice on boost problem
RabReith89
402
Aberdeen, Scotland
Hi i have been having a boost problem for about a month now, where my car is not boostin at all it drives like its a 1800cc??
Befor it got to this stage it was just boosting on and off, now the TCS light stays on aswell as the EML.
The car was been maped by c-codes about a week befor this started, am sure the map is not the issue.
I have been reading alot about this type of problem and most cases its the n75valve or the maf sensor.
Parts i have replaced so far: 4x coils, 4x spark plugs, new n75valve F, New maf sensor, cheeked all hoses ect
Had my car vag-comed to day and this is the fault codes thats coming up guys.
Monday,31,August,2009,15:43:03:32585
VCDS Version: Release 805.4
Data version: 20090602
Address 01: Engine
Control Module Part Number: 6K0 906 032 AA
Component and/or Version: 1.8L 20VT EU3 0002
Software Coding: 10500
Work Shop Code: WSC 13367
Fault Codes have been Erased
7 Faults Found:
3 - EVAP Purge Valve (N80): Short to Ground
P1425 - 35-00 - -
5 - Boost Pressure Regulation Valve (N75): Short to Ground
P1547 - 35-00 - -
5 - Oxygen (Lambda) Sensor Heating Circuit: B1 S2: Short to Ground
P1117 - 35-00 - -
3 - Secondary Air Pump Relay (J299): Short to Ground
P1435 - 35-00 - -
9 - Secondary Air Injection Solenoid Valve (N112): Short to Ground
P1421 - 35-00 - -
5 - Boost Pressure Control Valve (N249): Open Circuit
P1287 - 35-00 - -
2 - Oxygen (Lambda) Sensor; B1 S2: Internal Resistance too High
P1114 - 35-00 - -
Readiness: 0110 1101
Dont know why the n75 valve is coming back??
Plz help me get my little pocket rocket running agen
Thanks for any advice or help Rab
RabReith89
402
Aberdeen, Scotland
UPDATE
Well guys went out today and u where all right it was the number 8 fuse 10 32v, got a new one... soon as i put it in and turned on the engine the TCS was off and the car is running fine :)
Thanks for the help guys Rab
ebo007
185
Dundee, Scotland
I was more specific tho silencer... :lol:
Mine blew it all the time, had it in the garage and everything before someone on here told me the same.
I now carry a spare fuse in the ashtray. :D
