Need a new glovebox... would this suit?
mallett
53
Bristol
Yep. Mine was under a tenner and they had it in stock. Comes complete with the handle and mechanism. You get to reuse the lock. :)
mallett
53
Bristol
Easy peasy to fit. Remove the handle. Yank it off if it's not broken off already.
You'll see what can be described as a grey plastic star or torx head on a flat pice of plastic behind the handle. Push that down towards the floor pan direction. The door will open. You can see that the rear of the mechanism is behind a long flat cover which you need to unscrew I think. Or clips off. Without pics it;'s still obvious what you need to do. :) you just remove all the bits that you got new from teh dealer and replace with new.
kineticz
Forever moddin'
Jul 23, 2008
1,958
Shropshire
www.wepaintanypart.co.uk
Tim I didn't realise it was you at first from TA [B)]
Good to see you on this forum. The help is appreciated - seems a very easy job indeed.
And that bike looks sexual.
