Hmmm this is an Israel thing where they don't seem to want you to have navigation maps. VAG didn't supply any of their cars with map card for mib2. I've helped out people living in Israel and Palestine on this one before for mib2. For where the map card isn't supplied for mib2 you buy one of internet and down load the map for the region. That worked. If the car is imported from Europe as second-hand with a map car (seem to be a lot of those in Palestine) you have to do a bit of file work covered in here:
This
resource is applicable to all Seat navigation systems plus other Vag brands which are MIB2 / 2.5. It is built from the knowledge base on the Leon forum from a long running thread which has the advantage of tracking the twists and turns over...
www.seatcupra.net
Under "
Got a car with a working installed map but outside of the region - need to get local map working ? (Mib2 Standard only)"
MIB3 possible solution
Well that above is MIB2 standard your issue is MIB3 this is more experimental but I have been trying to get Seat people to try this out. Haven't heard back yet thou. Whilst uploading maps off the USB was reported to
not work in the early days of MIB3 Skoda folk say it
does work now. You could try.
Seat website:
Click here to see all available car sat nav map updates for your New
SEAT Ateca. Update your Navi System here.
www.seat.co.uk
Yours is obviously the Israel link.
The instructions are not at the bottom of that link they are the old ones for Mib2. You have a TAR file for Mib3.
Use a USB. If you are using a Mac you must run Keka and CleanMyDrive on the USB after copying it to there. 7zip on a PC.
Use the instructions attached from VW Mib3 covers it.
To my knowledge nobody has done this yet on the board but worth a try. You follow the VW PDF but use the Seat file link for Israel. You have to search for the menu option that kicks it off on your car.
Feel free anybody else out of connect contract to see whether you can get this working.
Mib3 units basically use the same approach to updates as the MIb2 high if you aren't on connected services. The website and instructions available were curious but un tested on Seat. Why do Seat put the mib3 files up if you can't do it. Some said in the early days it was for East Europe etc where connected services aren't available. Now as reported Skoda folk in the UK say you can do it. Either Seat's have a navigation FeC in them that stops the upload or it can be done or may be in Israel. I did say experimental. Well worth a try.
