N75
greesha
Leon 1.8T on steroids
Jan 6, 2009
496
Slough
Hello
I have a question about N75 valve. I noticed that some of us change it to a different one. Are there any REAL advantages coming from that ? Ive read that it helps to kep a higher boost but ... im not sure if that will be healthy for my engine if it was remapped to use some specific boost.
Can anyone who has changed his N75 valve tell me if its really worth it ? Maybe some dyno runs ?
Thanks in advance
Cupra Ross
Breaks things............
May 15, 2005
1,379
Edinburgh, Scotland
Hello
Thanks in advance
Its not worth it unless your car is remapped and you're getting surging with your current N75 valve. A lot of people change them for an N75J but most go back to stock.
The N75J doesn't physically give you more boost, it just reacts slower to the ECU telling it to open the wastegate to get rid of excess boost. An unwanted consequence of this is that it also reacts slower to the ECU telling it to close the wastegate when it wants more boost. It can cause a bit of "kangaroo effect".
Most people find that it gives a higher initial boost spike but lower sustained boost levels. Personally, I'd stick with the stock N75F valve that will be fitted to your car at the moment.
greesha
Jan 6, 2009
496
Slough
Thanks Cupra Ross !
Is it worth it to change that valve if im planning to do stage a 2 remap ?
Cupra Ross
May 15, 2005
1,379
Edinburgh, Scotland
I have a stage 2/custom map and I'm running a standard N75F with no problems. I had a GIAC map on a previous Cupra and that suffered from horrible surging, I would've tried an N75J on that but as long as you have no surging I think you'd be better sticking with the standard N75.
CupraUK
Pushing on
Aug 15, 2005
1,350
Bedfordshire
If you do decide to change from stock, I'd go for an N75J (which I used to run) as opposed to a far more expensive ECS race N75 which I have now. There is little difference between the two.
turbin
hello! I changed to the "H" valve and I get aprox 2-3 psi higher boost all across the rev range. + it picks up much much faster. There is a slight surge on partial power in 5th and 6th gear between 1500-2000rpm. Like it takes a while to settle... but its all good :D
dainott2105
mk1 Cupra and mk2 FR TDI
Nov 4, 2006
685
swansea
Mine has just started surging strangely. Remap has been on for a good few months and only seems to do it sometimes. Worth changing to the N75J?
DannyC87
Rubbing is Racing :-)
Mar 4, 2008
3,459
perhaps just try another n75f, they are pretty hit and miss as to whether you get a good one! my brand new one was worse than my old one!
