Right then mate lisen here, DONT bother with a different n75 as its all controled by the map ie my standard n75 can be told to open at any psi and fitting one that opens at a different psi to what your map asks for WILL only lead to problems.... Its a mugs game mate and folk who do it are only suckered into what the boost spike says and it WILL fook your turbo up ... end of story.
So most of the MK3 owner had better watch out..?
My map asks for a spike of 1.3bar tailing off to 1bar constant, which I get. With the new N75 valve, does the same thing spikes at 1.3bar....... but last that little bit and I mean "little" bit longer before it tails off back to the maps request of 1 bar.
As Kriso says seems a little smoother lower down the revs and not as jerky.
N75 valve only controls the wastegate opening and closing. Just leaves it open that bit longer than usual.
Also My maps graph has smoothed out more than the bumpy one here....
http://www.seatcupra.net/forums/showpost.php?p=1784654&postcount=17
And Revo stage 2 requests about 1.5bar or more boost spike.... then I think I'm still within the limit of my turbo.
If it does go BANG then it's more of an excuse to the girlfriend to get an IHI.
