How do I test my N75 valve with VAGCOM? It's on a Leon 110 Tdi (ASV) engine. Thanks Matt
matt-doyle Guest Mar 16, 2007 #1 How do I test my N75 valve with VAGCOM? It's on a Leon 110 Tdi (ASV) engine. Thanks Matt
acidstrato My Fast says shut up! Dec 9, 2004 5,942 0 Newport, South Wales Mar 16, 2007 #2 does it have one?
acidstrato My Fast says shut up! Dec 9, 2004 5,942 0 Newport, South Wales Mar 16, 2007 #4 solves that one then if its the same as the 1.8T, then log block 118 and note the wastegate duty cycle load,
corradophil Active Member Sep 14, 2004 228 0 Essex Apr 17, 2007 #6 I'd be interested in finding out how to test the N75 is working correctly too.
acidstrato My Fast says shut up! Dec 9, 2004 5,942 0 Newport, South Wales Apr 17, 2007 #7 as i posted above, log the duty cycle and compare it to those of a known working part on a 1.8T 80-95% when on boost is fine
corradophil Active Member Sep 14, 2004 228 0 Essex Apr 17, 2007 #8 acidstrato, cheers for that, I was not sure what it's meant to be.
