N75 Race valve
Dan Cupra R
The Yellow Sub
May 2, 2006
1,514
Reading
Just an update. Fitted my n75 valve today and it seems to have cured my boosting problem.
Ive only driven it for 5 mins so I cant say for sure that the N75 race valve wont make the car run dodgy but so far so good. Just thought Id update.
Deleted member 12147
I fitted my race valve today and it now feels alot better. Before fitting i was peaking at 21-22psi dropping to 18-19, now it peaks to 25psi and drops to 21psi. I took it out on a 2hr run today and i've had no limp mode issues, it seems to pull harder aswell.
karlosR
TORQUEY, NOISEY V6
Mar 10, 2006
1,469
BEDFORD
i've spoken to alex at TTS about the ECS race valve being a re-labelled N75-H. he reckons that it is a H valve but has been modified somehow by ECS. i guess the only way to find out is to do a comparison test between the two. i've had mine on for over a year now with no problems at all.
Yeah, the only way you would be able to tell is by fitting both valves to the same car, you can't tell from the race valve because the part number has been removed.
Mar 10, 2005
1,439
Walton on Thames
yeah its fine. I do have the EML and TC light on permanently but I'm quite sure its not n75 related as its running fine....still searching for a kind vagcom user
