Sounds about correct 95.3% until about 3000rpm on mine it then drops back down to about 71% duty cycle at the mid point it then starts climbing again and mine hits 85% by 6800-7000rpm. What duty cycle are you see 6500rpm-7500rpm. I am pretty sure i have warped/cracked my exhaust housing and the exhaust gas that should be spooling the turbo it leaking direct to atmosphere. I am changing the map sensor on thursday as jabba said they would change it anyway, so i might as well save the labour time and do it myself before it goes. Looks like i might have a .20 housing on though.
