how much of this 4mm pipe do you need?
also is this backup not needed because the forge valve isnt likely to fail? unlike the oem one.
Well, I fancy giving this a go over the next couple of days and TBH I am getting a little confused... here is my engine bay as it stands now.
To bypass the N249...
Red circle (pipe to DV) should go to the T-piece in the green circle? What happens to the connection in the red circle now there is no pipe attached?
Pipe in blue circle needs to be capped off somehow. Is that right?
