N249 Bypass question?
JamesE
157
Hey guys,
Ive just done the n249 bypass to my car and the dump valve is now makin a fluttering noise(split-r dv btw) ive tried adjusting it but cant get rid of the fluttering
Anyone got any idea what to do?
James
Beaker™
Slightly Unhinged........
Nov 21, 2005
1,900
C:\UK\Glos
Maybe since doing the bypass your DV vac hose is longer/shorter than it used to be? Would that maybe affect the settings required on the Split-R? (Just a guess by the way)
JamesE
157
ill try and get a pic up of the bypass so you can see if its done right!!!
JamesE
157
n249 bypass question pic now included
heres a pic!!
just need to change the big T piece for a little one!
James
JamesE
157
dv not fluttering now after i put a smaller T-piece on and putting the dv back to the setting it came on
James
Jan 8, 2007
2,958
Wiltshire
Did you see any advantage using resistors over the mechanical bypass or is it just a neater and "more proper" way of doing it?
Jan 8, 2007
2,958
Wiltshire
Yeah been reading through that with quite some interest but still unsure as to what advantage it offers over the mechanical way of doing it other than for tidiness?
