N112 Sec. Air Pump Valve Removal...
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
As people know I've done the N249 bypass, junked the secondary air injection system and soon won't require the second vaccum pipe going down to the standard K03. So I was just going to remove the N112 valve giving a totally clean rocker cover.
Anyone done this yet, any adverse effects due to the ECU not finding the N112? If not I'll give it a go see what I find.
Craig!
IHI Ibiza Cupra
Jan 6, 2005
1,876
Guisborough
www.vagcars.co.uk
Thats the plan, just need to know if valve needs to give a signal to the ECU or not, was I see it it no longer does to the sec. vale or the actuator so it's just a dead end.
So if it doesnt need a vaccum to send a signal it can be junked. Will sort the N80 out shortly just got other things to do first.
