My ibiza cupra isnt boost (Logs Done ect)
DaNnY_LaD
Big Turbo Leon Cupra R
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Right carryin on from my thread :
http://www.seatcupra.net/forums/showthread.php?t=147840&page=2
I kinda need some advice as i dont now what im lookin at...Basically i have no boost at all and when it does deside to work it will work till 3.1krpm then just cuts out..
Ive done all the check for boost leaks and there all fine...Im gettin really poor fuel consumion around 40miles to a 10er without boost as it aint working...
Anyway Djscorch(adam) done me a log and scan before this is what came up..
All i know is that i need a new lambda sensor but no idea which one..Also a CTS as im still on the orginal tbh..
I have disconnected the battery a few weeks ago and unplugged the maf last night to rule it out..
And i do have a open induction on aswell..
VAG-COM Version: Release 311.2-N
Chassis Type: 6K - Seat Ibiza
Scan: 01,02,03,08,15,17,25,35,56
Address 01 -------------------------------------------------------
Controller: 6K0 906 032 AA
Component: 1.8L 20VT EU3 0002
Coding: 10500
Shop #: WSC 00000
6 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 35-10 - - - Intermittent
17963 - Charge Pressure: Maximum Limit Exceeded
P1555 - 35-00 - -
17832 - Secondary Air Injection System: Bank 1: Leak Detected
P1424 - 35-10 - - - Intermittent
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
16486 - Mass Air Flow Sensor (G70): Signal too Low
P0102 - 35-10 - - - Intermittent
Readiness: 0000 0000
__________________
This is the log i did this afternoon and i only went to 4krpm as it wasnt goin anymore as there was no pull/boost what so ever..
m0rk
sarcasm comes free
27,787
33
Clanfield, UK
P1555 - 35-00 - -
is your wastegate broken
MAF is dead also I guess from the low signal, and the coolant sensor needs replacing too
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
i have no idea if my wastegate is broken..
is my maf defo dead?
Also what about the cts and lambda?
Just need a list of thing i need to replace..
Edit: Mork i did unplug my maf last night and then took it for a run...So that is what the error is as it stored it..
Big_daddy
Going going gone.....
Oct 20, 2006
3,930
Brummy
You pre- lambda sensor is dead (open circuit) .
Maf is givving a very low reading of 70/gs , for a 150bhp car you should be expecting anything above 120g/s from the maf. ( 150bhp x 0.79 = 118.5 g/s)
Big_daddy
Oct 20, 2006
3,930
Brummy
lamda controlls the air fuel mixxture, so if its lean the car wont boost correctly, not quite sure about the cts, but think it has similer roles to ensure the car is warmed up properly before full power can be achived.
Jus checked my mates temp today his temp gauge moving up and down at stand still. :confused: so his temp screwed as well. it must the season.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
Aright...
As i have no boost what so ever in any gear...Drive like **** tbh...And my fuel consumption is really bad...Ive been quoted 65quid each for the lambda but i need to now which one and were it is...
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
when you reset the codes which ones come back.
terminal 30 voltage... you disconnected battery?
earths ok? so many faults to be there at once.
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
i disconnected the battery the other week to clear the codes so that is what that code is and the maf one is when i unplugged it to test it and rule it out so that that code..
the others have come back but i dont have no dash light (EML) at all..
And the car just wont boost ...It sometimes will then cut out well before its begans to spool up
Big_daddy
Oct 20, 2006
3,930
Brummy
the code dont clear by disconnecting the battery, they clear only via vag.com
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
aright...Must be different to my old vauxhall then..
but yeah the 18010 - Power Supply Terminal 30: Voltage too Low
is me disconnecting the battery and the other unpluggin the maf...
So that leaves 4 to be explained?
Big_daddy
Oct 20, 2006
3,930
Brummy
Thats 2. the power supply only occurs when you discoonect the batery, the 22nd is maf to low, the maf needs replacing
DaNnY_LaD
Jun 2, 2007
4,814
Manchester,Walkden
www.myspace.com
yeah the maf is when i unplugged it 2 night ago and then went for a drive to see if it ran anybetter?
So the CTS & Lambda are causing my poor fuel consumption..
Now would the N75 cause my boost issue as im still on the orginal one..
Big_daddy
Oct 20, 2006
3,930
Brummy
personally think, fit the new lambda sesnor and new temp sensor, then check the boost. if the boost is still not rising, the n75 is the next step.
Big_daddy
Oct 20, 2006
3,930
Brummy
Rang gsf parts for a temp sensor for a 1.4ibiza, it came around 13.63, you may want to give them a try.
