on the 25th of April last year, i had my brake pads changed.
now a couple of days ago, i noticed the remaining level on my pads is extremely low and would require changing anytime now.
also, i have this shuddering when braking from high speeds.
popped past my local VW a few days ago, and they confirmed my 'maintenance plan' won't cover anything on my braking system (discs, brake pads and brake linings inclusive of labour) until i reach the 25th of this month (being 1 year/20000km, whichever comes first).
now my right hand side pads are starting to make a noise, sounds like metal to metal although there's still about 2-3mm left on the pads. why is that?
what should i do?... i have come up with the following would-be solutions:
1. should i go and buy performance brake pads in the interim, have them fitted and wait until the 25th to get discs and linings done?... this in mind is to avoid any damage.
2. should i drive like an old lady till the 25th, then get it all done under my 'maintenance plan'?
which of the above would you do taking into consideration the seriousness of the matter?
thanx,
FR
thanx,
FR
