jimmer111
Having done quite a bit of research on here i changed my gearoil to Redline MT90. The reason being, when cold it would crunch changing from first to second.
Got the garage to change the oil for me with the last service (I provided the MT90 for them) have done about 600 miles with it now and it is terrible. The crunch from first to second has got worse and it now does it 2nd to 3rd when cold also. Things do improve when warm but overall is a lot owrse than with the old oil.
Basically wanted to know if anyone else has had problems with this oil in their gearbox and what they did to fix it. Looks like i will have to source some OEM oil from the stealer.
Sorry for the essay but any help would be greatly apprecited. The car is an 03 LCR by the way.
James
Had the oil changed this morning to the OEM stuff from the stealer, garage did it for free (top stuff) and the problem is solved. No more crunching and super smooth gear changes throughout the box. Set off from the garage obviously with fresh cold oil and no crunch what so ever. Done 70 miles now on all roads inc. motorway and can't fault it.
In short, if you are going to change gearbox oil go for OEM stuff, it is best and what are gearboxes are designed for. The chap at the garage commented that the MT90 that came out was notably thinner than the OEM stuff.
Hope this helps people ou.
James
James
James
