Phil_beeza
461
i was thinking....the bloke before me had a body kit put on, there is basically a shelf going underneath the front all the way across (ie..a body kit :))
i guess this almost acts like a 'scoop' which picks up air at the lower front, rather than letting the air slide underneath the car.
would i get better mpg be either removing this front spoiler, or was thinking of (ouch...) chopping off at either end, so that i kepe the corners, but the front of the car itself has no ledge, so the air can slide straight underneath and not be scopped up
Do you mean a front splitter ?
Difficult to make out from the picture, but I'm guessing the black round the front isn't just shadow :confused:
Shouldn't make any difference to MPG at all (well, barely)
Any 'scooped' air will be going through the bumper, into the engine bay - cooling and aiding engine efficiency ;) - then out the bottom and under the car
Remove it if it's a matter of styling taste, but not if you want to save anything in fuel efficiency
that black is just shadow :) the white is the lowest bit
as far as the spoiler itself goes im not sure what i think of that upside-down 'U'
ps, what is a front splitter?
Think I get you now :)
You'll hear endless talk on here about the LCR (Leon Cupra R) front splitter
It's the black plastic strip that sits at the bottom of the bumper
A nice aerodynamic styling feature ... and at around £20, a cheap way of finding out when you're car's too low for speed humps
haha....
ah i c. does it 'slice' some air up into the engine?
ps, is that your motor? sweesh ;)
