As I promised I am finally getting round to doing a " How to guide " to fix the rear washer problem, this should sort the following problems:
Moving washer jet when wiper is on
Short length of jet
Leaking screen wash from behind boot trim (could be hose popped off though)
Please bare with me as this is my first how to guide and it may take a little time to finish
Part Number I used : - 8LO 998 711 available from Seat or VW
Contents of kit are shown in pic above
1. First thing to to do is remove the inner boot trim. This is quite tough and I was worried about breaking it as alot of others were, so I have read. To remove trim undo the 2 "posi" screws, one located in each grab handle . Next is the horrible bit, the trim is now just held in with "pop in" trim clips. I removed the foglight access panels and put my hand in and prised the trim off that way while also pulling on the grab handles.
2. Skip this section if your washer jet moves as you know its definetly broken. With the boot trim off you will now be able to see the wiper motor assembley and the screen wash pipe. Get someone to sit in the car and squirt the rear washer you can check for where the leak is coming from.
3. Now with everything checked first thing to do is make sure u have the wiper motor repair kit and some kitchen towel or rags.
4. Remove the rear wiper arm by lifting up the cap and undoing the nut on top. From memory I think the nut is 13mm some penertrating oil or WD40 is handy at this point as some people have found that the wiper arm is quite difficult to get off.
5. With the wiper arm removed i disconnected the washer pipe from the back of the motor assembley and wrapped the open end with some rag incased there was any leaking. I also disconnedted the wiring too.
6. This now leaves only the 3 bolts holding the motor in. Undo the 3 bolts being careful not to drop the motor on you head !!
7. With the motor removed I went inside where i had a decent surface to work on, as there is a number of parts to strip on the motor.
8. Put the motor on a flat surface, undo the 7 bronze coloured torx screws on the silver plate
9. Remove the plate, the bronze tube will be attached.
10. The old bronze tube needs to be replaced with the new one from the kit
The difference in length between the new and old tubes
11. The internal spindle will need to be removed and replaced as part of the bronze tube may still be seized or stuck inside, the kit comes with a new spindle any way.
12. In the Kit will be 2 different tubes of grease with the separate part numbers on the tubes themselves. Using the one listed on the sheet of paper included in the kit coat all moving parts and the spindle, insert the spindle and the lug into place.
13. Clip the new brass pipe into the back plate and screw the plate it onto the housing.
14. The instructions say to now insert the new plastic jet into the brass pipe. I felt that it would be better to reassemble everything into the boot first so that i can make sure the jet is spraying in the correct direction. Be gentle as i managed to snap the new jet and had to use the old one.
15. Bolt the assembly back onto the tailgate reconnecting the fluid pipe and the electrics. Before replacing the wiper arm check the spray and the direction of wiper arm movement.
16. Fit wiper arm on, and gently pust plastic jet into the brass spindle making sure the jet faces directly upwards ! !
Stand back with a cup of tea and admire your handy work and think how much you have save on dealer labour costs.
Short length of jet
