MOT today
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
:cry: It failed Worn Front brake pipe the flexie one, and rear brake light bulb blown, interesting thing is i have a small number plate on and as of April it will fail the mot, (good job i have the original and some velcro for next year) also the centre exhaust bracket had snapped but not failed on it, and outer cv boot split also not a fail, having all done on Tuesday, going to put braided hoses on, and replace the centre section with the diesel centre section as it has not got the silencer in it, for £20 worth a go:D
LEE69
Stage 2 Revo'd
Dec 10, 2004
21,262
74
C\UK\Devon\Torquay
http://www.motuk.co.uk/manual_250.htm
E. Front Wheel Drive Shafts and Couplings
Inspect as follows while the front wheels are jacked up
1. With the vehicle in neutral gear, rotate the wheels when they are on each lock in turn, and check visually the gaiters of the outer constant velocity joints while the pleats are expanded.
1. a. an outer constant velocity joint gaiter missing, split or insecurely mounted to its housing
andycupra
status subject to change
common MOT faiulure the centre bracket. same onthe golf.
Dealer will rape you if you want it fixed there.
A decent garage will weld it for not alot.
some people get advisories where the centre / back box join if they have aftermarket exhausts.
CV boot is a fail.
Robb1990
299
My centre mount has gone on mine and was rattling, so i bodged it with a jub clip, ive got the MOT end of this month, think it'll get through? Its not loose, i just fixed it with what i had to hand lol. Meh, might take it an exhaust place anyway, need to price up a mufflerectomy :rolleyes:
