Had my Seat Ibiza Mot'd the other day. Everything seemed to be going fine until the dreaded emissions test! I was told it was mostly likely the Lamda Sensor which is located on the front of the car.
It is 1.4 litre engine, 'R' reg 98 model. I have ordered a new Ngk lambda sensor ;
http://www.ngkpartfinder.co.uk/car_...anufact=SEAT&model=AROSA&engine=1.4&pos=Front
part no: OZA447-E32, Engine : APQ (im pretty shore this is right!)
I just want double check how you remove it. Above it is a heatshield with 3 very rusty bolts which look as if they are going to break as soon as i try to undo them.
Then underneath this is the sensor. The nuts on this look quite rusty as well and im worried about breaking it - trying to get it off.
I will spray the bolts with loads of WD40 when i do it.
Has anyone got any advice on how to go about this.
many thanks
many thanks
