t3zza
hi guys fitted new front pads yesterday with no real probs , today i attempted to fit new rear shoes having never done them before i thought they looked quite complicated with all the springs & tyrin to remember where they go.having took the hub off i realise that i had not bought a new split pin with my shoes & so decided to keep theses shoes on until i bought pin, but first i wanted a go at seeing if i could take shoes off & put back on well having cojouled them off without releasing tight bottom spring i tried to put back on the same way while trying to get flange behind piston flange i knocked off rubber seal & out poppep the unit & a small spring acompanied by some brake fuid, i put everything back together & put car in garage but noticed i had no brake at all slightly spongy then nothin ,is this just typical of allowing air in the system ? how should i bleed the system ? any info would b appreciated.
i also noticed that on old brake shoes on car there is a bar mechanism running horizontally between the two shoes , my new shoes do not have this do i just fit the one that on the car?
thanks
thanks
