remove the airbox. Then remove the engine beneath it. Then in its place, put a 1.8t 20v engine. That will improve things
seriously tho, I'm sure it's been done plenty of times, and a good search should fin you the answer
I agree. My induction kit made it sound a little nicer, but at the same time, didn't feel right. Then again, my car has got problems lol
smooth out inside of airbox as much as possible - alot of peeps use a dremel to start
get a green panel filter - proven to work good and cheap (available from badger5)
fit approx 80mm/100mm cold air feed
good writeup with pics and results here
http://www.seatcupra.net/forums/showthread.php?t=65944&highlight=smoothing+airbox+pics
hope this helps
sounds like a good idea i have a green cotton induction doesent do anything!
if it was a year ago i would be doing the same. im gettin a cupra soon becuase i can aford to finerly insure one. got mine lowered shocks and springs with sum wide alloys on handle like a go cart lol have you lowered yours yet?
Best cold air feed is from the fog lamp cover like mine or you could have it coming from above the fan because its in the direct wind from the grill. Use 2 cable ties job done
Gordz, im thinking of doing the same to my air box on my 1.4, is it worth it? plus how did you attatch the cold air feed?
Yeah I reckon it's worth it, I've just smoothed out the inside, put performance panel filters in and connected up a cold air feed that was from my old K&N induction kit and attached that to the side of the air box where the original hole is.
I've got my cold air feed located just straight down the front of wheel arch kind of thing and that seems to be just fine, although i am thinking of moving it to where fog lights should be as I don't have any!
So yeah it is worth it, especially with price of petrol, getting similar noise / performance from my air box as I did with induction kit, in fact i'm getting better performance as now my engine isn't sucking in hot air like it was with the induction kit!
Nice one you got any pics by chance? did you just attatch the feed to where the little shtty trumpet shaped air intake is on the engine cover??
