vagcommed today and these came up , deleted and the same ones reappeared straight away
VAG-COM Version: Release 311.2-N
Chassis Type: 6L - Seat Ibiza
Scan: 01,02,03,08,09,15,17,19,37,44,46,56,69
Address 08 -------------------------------------------------------
Controller: 6L0 820 043 A
Component: CLIMAtronic PQ24 0201
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
01271 - Positioning Motor for Temperature Flap (V68)
000 - - - Intermittent
01272 - Positioning Motor for Central Flap (V70)
01274 - Air Flow Flap Positioning Motor (V71)
Address 09 -------------------------------------------------------
Controller: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
01598 - Drive Battery Voltage
27-00 - Implausible Signal
Address 46 -------------------------------------------------------
Controller: 6Q0 959 433 E
Component: 37 Komfortgerát 0002
Coding: 00064
Shop #: WSC 06402
1 Fault Found:
00929 - Locking Module for Central Locking: Front Passenger Side (F221)
27-10 - Implausible Signal - Intermittent
End -------------------------------------------------------
ive done a search and have heard of the codes being mentioned but no actual write up of any work that has been done to rectify the situation ,
the battery one is what im most concerned about , the car starts and drives perfectly and the voltmeter ( seat instrument cluster) says its ok , so where does this signal come from , alternator plug????
the passenger door intermittent , think il pop the door card off when i get a chance , n check the connections etc , altho this is working fine also , am confused ,
dont even mention the climatronic codes as from ive gathered all that gubbins is behind the dash , but again it seems to work ok , its just vagcom says it isnt ,
any help is appreciated as ever
Coding: 0000000
Shop #: WSC 00000
3 Faults Found:
Coding: 00140
Shop #: WSC 06402
1 Fault Found:
Coding: 00064
Shop #: WSC 06402
1 Fault Found:
