Hi.
Long time reader registered and this is my ride.
I got that car 09/07.y first register 01/07.y
Type 4 Cyl. - 5V
Displacement (cc) 1781
Cylinder bore and stroke (mm) 81 x 86.4
Compression ratio 9.5
Maximum power (kw (hp)/rpm) 110 (150) / 5800
Maximum torque (Nm/rpm) 220 / 1950-4500
Fuel supply system Multipoint injection
Integral electronic ignition MPI
Fuel type ROZ 95
Accelerator control EGAS
Emission control EU4 / TIER
Alternator (A) 70/90
Battery (Ah/A) 60
PERFORMANCE
Maximum speed (km/h) 216
Acceleration 0-100 Km/h (s) 8.4
Acceleration 60-100 Km/h (s) gear n 9.2
Acceleration 1000 m (s) 29.1
FUEL CONSUMPTION
City driving (l/100 km) 10.5
Extra city driving (l/100 km) 6
Ponderable consumption (l/100 km) 8.1
CO2 MASS EMISSIONS
City driving (g/km) 259
Extra city driving (g/km) 144
Ponderable (g/km) 180
TRANSMISSION
Gearbox type 02R.E
Ratios I 3.300
II 1.944
III 1.360
IV 1.034
V 0.816
VI –
R 3.060
Group ratio 3.647
Speed 1000 rpm in V (km/h) 36.3
SUSPENSION
Front Independent type McPherson, 2nd generation bearing (bearing + hub). Stabilising bar U 19 mm.
Rear Directional effect shaft, suspension longitudinal arms. Semirigid bar without stabilising bar.
Steering system Standard servodirection
Turning diameter (m) 10.6
Brake system ABS std, TCS std and ESP opt.
Type brakes: front/rear Selfv. Disc/Disc
Front brakes (mm) 288 x 25
Rear brakes (mm) 232 x 9
WHEELS
Rims 17”
Tyres 205/40 R17
DIMENSIONS
Type 5 doors
Length/width/height (mm) 3993/1698/1441
Wheel base (mm) 2460
Trunk front and rear (mm) 1419/1408
Boot capacity (l) 267, with back seat down and space up to front seat/roof: 665/960
Petrol tank capacity (l) 45
WEIGHTS
In running order without driver (kg) (2D/4D) 1154/1179
Maximum weight (kg) (2D/4D) 1649/1698
Maximum weight with brake (kg) 1200
Front seats- yellow and black lether.
KHS replica blowoff.
Rear lights : Silver colour finish
Door handles :4 doors, car colour.
Fog lamps
Colour-codec dual bulb headlamp kid with 5000k xenon lights.
Type 4 Cyl. - 5V
Fuel type ROZ 95
Battery (Ah/A) 60
PERFORMANCE
FUEL CONSUMPTION
CO2 MASS EMISSIONS
TRANSMISSION
Gearbox type 02R.E
Ratios I 3.300
II 1.944
III 1.360
IV 1.034
V 0.816
VI –
R 3.060
Group ratio 3.647
SUSPENSION
WHEELS
Rims 17”
Tyres 205/40 R17
DIMENSIONS
Type 5 doors
WEIGHTS
Fog lamps
