Mk3 Ibiza Cupra Clutch HELP
Jan 31, 2008
529
Hey guys and girls im really in need of some help please.
im in the market for a new clutch, ive been doing some research and some people go for the VR6 Clutch and G60 Flywheel, does anyone no the advantages of going for this setup? also would any modifications need to be done to fit them?
Any info would be great
also if anyone on here as fitted them do you have the part numbers of the ones you fitted, thanks
cupramillo
The "Red Baron"
Feb 24, 2008
2,039
South London
I have the VR6/G60 setup on my cupra on ko3s and its very good. Loads of threads on this. No mod needed to fit, goes straight on.
Jan 8, 2007
2,958
Wiltshire
You really need to search harder...
G60 flywheel part #: 028 105 269 BX
Bolts: N10 101 001 & N90 206 103 x6 EACH
Part # from Euro Car Parts for clutch kit is 641440660
(Look under the VW Golf 1997 VR6)
Straight swap, can handle more torque than the standard clutch and the single mass flywheel is much lighter so the revs pick up quicker.
Flywheels:
OEM G60:
• Steel construction
• 21.6 pounds
Eurospec:
• Billet steel construction
• 14 pounds
• Most inexpensive
Autotech:
• 11.8 pounds
Autotech:
• Aluminum construction
• 8.3 pounds
Fidanza:
• 6.5 pounds
