Hi all,
My 2012 Leon Supercopa Diesel needs discs and pads changing.
From searching on here, I’m pretty confident they are:
288mm front
253/255mm rear.
Im under the impression that I do not need the multi-spline tool as the caliper carrier at the rear can stat attached and the discs still removed. Please shout if that is incorrect..
I’ve got a wind back tool and an otherwise full set of spanners, so think I’m good to go.
Question is though, are these the correct torque settings?
Wheel Bolt Torque - 110Nm
Disc screw - 6Nm
Caliper Pins - 30Nm
Carrier bolts (front) - 200Nm
I’ve taken these from threads on here but these are mostly in the mk1 forum, so not 100% sure if they’re applicable to mk2 with above caliper/disc sizes.
cheers!
288mm front
253/255mm rear.
Disc screw - 6Nm
Caliper Pins - 30Nm
cheers!
