mk2 ibiza badge removal
fresh_creps
166
Bedfordshire
hey all,done a search but haven't found anything really helpful...but how do you get the front "S" badge off,can only see the 3 screws holding the top of the grill on so can't really get behind the badge.
also what is actually the easiest way of removing the rear "S" badge aswell,as the screw underneath it is a strange security screw??
thanks in advance :)
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
theres 2 bolt slot type fitting under each indicator as well
iirc its melted on the back and the centre black section is too - you can demelt it and screw em back on but dont get the screws too long or they poke out the front
Fl@pper
Jun 19, 2001
12,368
25
Gloucester
bumper stays on
indicators out - undo bolts each end - undo 3 screws on top - grille comes away
bumper is held in on each wing side and 2 torx bolts under the grille
2 sec ill find a pic
